Trevor, Have you joined the Fisher use group? https://groups.yahoo.com/neo/groups/ffphomebuilts/info
This is your best source of Fisher specific information.
SpecificationsEngineRotax 503Rotax 582LCEngine Hp5264Wingspan31’31’Wing Area140 sq. ft.140 sq. ft.Height5’7”5’7”Length18’1”18’1”Fuel Capacity8 gal.8 gal.Fuel Consumption @ 75%3 gal/hr.4 gal/hr.Design Loads+4.6 -2.3g+4 -2.2gDrive TypeGearedGearedGross Weight740 lbs.830 lbs.Empty Weight350-375 lbs.375-400 lbs.Construction Time500 hrs500 hrsField Assembly Time30 min20 min
Note gross weight. Consider this when you start loading the plane. If you have an empty weight of 400# you have a useful load of 430 pounds - fuel with your extended tanks will be 180# leaving you with 250# for people and gear.
The Covering you mentioned is excellent but will be costly. Consider uncertified fabric and acrylic paint as the lightest and least costly of covering/finishing. see this http://bcove.me/hkevu2sh - BTW there is no latex in latex paint - it is all acrylic and should be called home acrylic paint for your aircraft
You are on a steep learning curve, Welcome
Jim Heffelfinger
FP-202
Yahoo groups moderator
