Originally Posted by
whemme
lvflyer,
At the Peoria, IL airport (KPIA), if you takeoff on runway 13 and proceed straight out, the only marker beacon off the end of that runway is the OM located 5.2 NM off of the SE end. There is no MM off the end of runway 13 so I don't see how it is possible that you can receive a MM light and tone off the end of runway 13.
On an approach to runway 13, both an OM and a MM exist. The OM is 5.2 NM NW of the approach end of runway 13 and the MM is 0.4 NM NW of the approach end of runway 13.
Look at the approach plates for both ILS Rwy 13 and ILS Rwy 31 to see what I am talking about.
I would recommend that you go see Greg Vail at Bloomington Avionics since you are located closeby and have him troubleshoot your marker beacon system.
