Originally Posted by
Greg Wilson
I know this response is quite late but here is my thought, with out seeing it. You likely have the lever for a hand "parking brake". The model 7 did not have the McDowell starter as an option they were in the mod.11 Chief. The McDowell starters that I have seen were operated with a lever anchored to the floor at the left side. I have the parking brake on my champ and most Aeronca owners, current and former, don't know what it is so I think they were not common. My system was installed in about 1950 after a "hand propping accident" according to the records. The McDowell starter worked as a recoil starter like a lawnmower engine. A ratchet was placed behind the prop with the cable running to the lever. The lever simply gave mechanical advantage rather than pulling the cable directly, like with a small engine.
