Thanks. How about the Cozy MK4?
I believe the Express is still in production. http://www.compairllc.com
I'm not sure how the cost compares to the RV-10.
It looks like the -10 drove the Lancair ES to mothballs. They say they will still make a kit for you, but they're not actively selling them.
Yes , Bob and there are few things that will have you more alert/nervous than doing the first flight in an experimental airplane that you and a friend have built, especially if it has a 2 stroke non aviation standard type engine. Worked out ok, though.
I believe the Sling 4 meets those requirements...
Dave,
Sorry I'm coming late to this discussion. Here is a list of all the kits I know about that seat 4 or 5 and cruise at 150kts or more:
AeroCad AeroCanard (4 models)
Auriga Designs Aerocat SRX
Bede Aircraft BD-4B / 4C
Lancair: ES / IV / Evolution
Ravin 500 RG
Team Tango Foxtrot 4
Van's RV-10
Velocity SE / XL
(There may be newer companies that I don't know about. I last updated my list in 2011.)
Some of these companies may not be around anymore. The companies with the largest installed-base of flying 4-person aircraft are Lancair, Van's, and Velocity (in that order.) In terms of the number of kits sold per year, the ranking is Van's, Lancair, and Velocity.
Hope this helps!
Reiff Lorenz, Dayton Ohio
Velocity XL-RG, 51% completed
Single seat
http://www.ultralightnews.com/ssulbg/index.html
Dual Seat
http://www.ultralightnews.com/ulbg2/index.htm
Tony
Check out www.pilotfriend.com. You'll have to search through the listings but they have info on most planes.
