http://www.lamatek.com/catalogs/hvac...nce-tape.shtml
77 to over 100 pounds per sq inch tension, 49 to 79 lb sq in. Dynamic shear, static shear 65-97 lb sq in.
Put a panel in place and it's held. Half the rivets and cleos to deal with. A few to choose from, from what I see plan on $270 to $320 a box of 10 rolls. But if time is money, sealing joints and preventing chaffing and rivets getting loose this may be a fantastic investment. window seals, air ducts, So many uses come to mind. This company also supplies bump stops foam tapes , speaker feet, 2 sided foam tape for electronic installs.
Hoghead.![]()
