Originally Posted by
BCAIRPORT
I'm sorry but I have to disagree with you comment. If you re-read the previous quote that you disagree with, the shield is stripped back from the center insulated lead, twisted to form a ground wire(as such) and that ground wire is soldered to the copper wire. Soldering this twisted lead, if done properly, will not heat the insulation of the insulated lead and will not compromise that insulation.
Also making a solderless connection as you describe, will not provide a perfect ground.(OR a lasting connection)
There are two methods to create a proper electrical connection. Mechanical crimp, preferred in most cases, and soldered (when properly completed)
Wrapping a conductor around another conductor and using shrink tube to hold it in place may work for a short term but time and nature will form corrosion between the two conductors reducing and/or preventing the connection integrity.
For lasting results, always either Crimp using proper avionics crimping tools or solder with proper heat and solder composition.
Bob Doughty A&P
