Sam,
Sorry I was not clear, when I stated "YOU" I was referring not to you as a person specificly, but as a component of a dialogue of information. If that makes any sense. It was never intended as a personal attack. You did however bring up what is my biggest gripe with the thought process going on here reguarding something like this. Simply put your past experience is meaningless for future decisions unless you can assure the material you are using has not changed. If you find fault with the previous logic, I would like to know how.
P.S. I do use "latex" paint quite a bit, on everything from my house, to equipment, to model aircraft. So I have nothing against the material technology at all.
