Like Frank, my charts are prepared before I get into the airplane. All I need do is glance down at them and the line I drew during my preflight. Or do most of you preflight while in the air?
Very safe
Relatively safe
Not very dangerous, but not very safe (neutral)
Somewhat dangerous
Very, very dangerous
Other
Cheers,
Jerry
NC22375
65LA out of 07N Pennsylvania
Well, we don't know that texting hasn't been a factor in any airplane accident. Perhaps it hasn't been cited as such but that doesn't mean it hasn't happened.
Isn't the issue with texting and driving is that the "heads down" time is distracting the person from the task at hand? I'm curious how "heads down" time while texting in an airplane is okay, shouldn't everyone be "seeing and avoiding" other traffic? Texting has absolutely no role in safety of flight like navigating and other things that some are saying is equally distracting.
Sad day for aviation when folks are defending texting while flying.
In my own aircraft I'll take a cue from the Army pilots and write freqs on the inside of the windscreen with an alcohol pen before leaving out.
Then again I'm still concentrating on the Aviate-Navigate parts of flying and Communicating only as absolutely required.
Rarely!
But that's when one buys a second sectional, tapes it to the first, and fold for a quick flip if required!
Bear in mind, though, that I fly a Champ.![]()
That's one solution. Another is to first fold your sectional down the middle (lengthwise) and the accordion fold it so that it is one panel wide. From that point, one can see the whole chart by flipping to open, page by page, like reading a book. Need to go to the other side of the chart? Easy - flip it over and open to the correct page..... Easier to demonstrate than it is to explain.
Cheers,
Jerry
NC22375
Actually, the FCC only prohibits the operation of ANALOG cell phones in flight. No such restriction on digital phones -- I looked it up on the FCC's Website. The old regulation still stands because the old analog phones could "lock up" several cellular nodes at once if they were elevated high enough. Digital phones do not have this problem. The FAA prohibits inflight cell use on Part 121 carriers.
I use my cell on the Hurricane. It's in a mount on the left hand side of the cockpit and I use it for foreflight and charts. I also keep a sectional or TAC on my kneeboard along with my VFR flight plan if I'm leaving the immediate area of the field.
Hy-Tek Hurricane 103
For me, texting while driving is dangerous than texting while flying. But when flying cellphones are prohibited right?
