Results 11 to 20 of 25
Thread: Private Pilot SEL and Amphibians
    Floats flyer,
    I go to the FAR's for my information, not sales reps. That doesn't mean I am always right, but I try.
    For an E-A/B, the definitive answer is in the aircraft's operating limitations. Most likely, category/class ratings are required.
    New Hampshire
    That is correct. If you would like some light reading, look up FAA Order 8130.2f. Start at page 161.
    Anymouse's Avatar
    2A2
    Getting back to the 1st hijack, IIRC, if the aircraft has more than one seat you need to be appropriately certificated/rated. If it's a single seat aircraft, then you're good to go, legally speaking. Flying solo with a two (or more) seat aircraft still requires the ticket. This is a loophole that was tightened several years ago.
    New Hampshire
    Anymouse, can you cite the FAR? I went looking and did not immediately find it.
    Thanks,
    WA
    Quote Originally Posted by Anymouse View Post
    A student pilot can solo a two seat Cessna 150 without any rating, just need an instructors endorsement in the log.
    A helicopter instructor once told me that since I have a private SEL, I don't require his endorsement to solo a helicopter.
    So where is the rule?
  6. #16
    Anymouse's Avatar
    2A2
    Apples and oranges. Student solo endorsements expire eventually.
    Go do your own research. You'll probably find it on the EAA website.
  7. #17
    FYI - I pruned this thread this morning, removing some off-topic bickering. Please carry on...
    Hal Bryan
    EAA Lifetime 638979
    Managing Editor
    EAA—The Spirit of Aviation
  8. #18
    Dec 2012
    Connecticut
    I don't think part 61.31 is the correct FAR to reference here. While that does technically allow someone to fly a experimental helicopter (twin, etc) with a only a SEL rating as long as it is allowed on the aircraft's operating limitations. I think this conversation would be better directed looking at how an aircraft is certified. According to the Type Certificate Data Sheet for the Lake LA-4 ( http://rgl.faa.gov/Regulatory_and_Gu...Highlight=lake ) the aircraft is a "Small Airplane". I don't believe (I could be wrong) that there is anything certifying the LA-4 as an Amphibian. Thus if you were to fly it strictly from land you would only need an SEL rating.
    Same for a C-182 on amphibious floats. I don't think adding the floats changes anything about how the aircraft is certified, thus if you wanted to fly a really slow, inefficient C-182 with only an SEL, you could add floats to it and only fly it from land.
  9. #19
    Quote Originally Posted by skier View Post
    Well, the TCDS says: 4PCAmM(Normal Category). Deciphered, that means 4 place, Cabin, Amphibian, Monoplane (Normal Category is self explanatory).
    I think you are saying if a plane is certified as a seaplane, the pilot would be required to have a seaplane rating, since it would be precluded from land operations, which would be correct.
    A C-182 is certified as a 4PCLM, 4 place cabin, land, monoplane but If you added straight floats it would become a 4PCSM and would require a seaplane rating to fly, since it would no longer be possible to operate from land.
  10. #20
    Jim Hann's Avatar
    Talked to a buddy about this thread. He did fly an amphib when he only had an ASEL rating AND got ramp checked. No problem from those Feds but that was a while ago. He is ASES rated now.
    YMMV
    Jim Hann
    EAA 276294 Lifetime
    Vintage 722607
    www.mykitlog.com/LinerDrivr
    Fly Baby/Hevle Classic Tandem
