Originally Posted by
Aaron Novak
Like everything in life, there are trade offs.The Ura powders excel in some areas and fall short in others. They are by no means a cure all or direct replacement for liquids. For corrosion protection in extreme environments, its hard to beat a conversion coating, epoxy liquid prime and enamel ( stoved or air dry ) topcoat. And keep in mind if you are going to use a primer that has a sacrificial pigment, the sealing traits of powders can hinder the primers performance. So I go back to my basic point, use the powder as a topcoat, and prep/prime as you would with any other topcoat. If you just do a single stage on bare metal.....well good luck with that.
P.S. Just so you know, I use both powders and liquids, not that I am partial to one because I dont have the other or anything like that.
