Originally Posted by
WLIU
There are two solid solutions to the Lyco camshaft issue. One is the Ney nozzles that put a spray on the cam lobes. No delay in lubrication at startup. Another vendor drills the cam to be like an automotive cam where there is again pressure lube.
The bad news is that you can only install these mods at engin e overhaul time. I did the Ney nozzles.
I run Aeroshell 100W+ all year round in New Hampshire, but I have a hangar and can preheat every winter start when the temps are below 35F.
