Quote Originally Posted by rcmodelr View Post
OK!!! Thanks MUCH!!! I tried it... It took over 5 minutes before it started playing, but so far, it's playing at least as well, if not better than the daily Air Show LIVE streams did.
This video is recorded at the same settings as it would have been if it was live. The only quality difference you may see if less hesitations as our server load is much lower now. typically we had around a 1000+ viewers at a time watching the streams and that was maxing out the server.
