Quote Originally Posted by Rhuzzey View Post
What is the best and readily available product for sealing the lexan skylights to the aluminum riveted frames and the windhield to the fiberglass molding and lexan windsheild.
I suggest one of the polysulfide windshield/window sealants like 3M Aerospace Sealant AC-251. It's made for exactly what you describe. Mask off 1/8" on each side of the joint, mix it up and brush it over the gap with a 1/2 length acid brush. Pull off the tape, let it sit overnight and voila! Won't have to worry with it again. Wear gloves cause it takes ~2 months to get it off your hands.
