Quote Originally Posted by rosiejerryrosie View Post
The short answer (and you won't like it) is don't buy it. The grace period for registering the previously titled "Fat Ultralight" has long past. The Kolb you are looking at is just good for parts to put on a registered Kolb. Someone else may have a solution for you but don't jump on this deal.
Just for clarification, the option for transitioning a "fat ultralight" to LSA is what has expired. Registering the Kolb as E-AB is still an option if you can pull together the documentation that has already been mentioned.
Obviously the Kolb needs a comprehensive inspection by someone familiar with the Firestar before you make a decision to write a check.
