My '41 J4A came out at 951 lbs empty weight. According to the 337s the typical weight before restoration was 819 lbs. The original included full electric with battery, old heavy weight starter, air powered generator, & had an A-75 Continental engine. This was all removed.
I substituted a C85 engine, a metal prop, a lite weight starter & a power socket. Otherwise no electrics, but ended up at 950 lbs!
Did someone at Piper originally have their fingers on scales pulling up? My IA says it is not at all uncommon. Has anyone else had this sort of experience?
