Waco QCF or UBF Drawings Lists
Greetings,
I am about to send in an order for the Waco UBF and QCF drawings lists to NASM. Before I do, I thought would check in here to see if anyone already has these lists on PDF. Seems so inefficient to send to NASM for lists, wait 3-4 weeks, then order drawings one by one and wait 3-4 more weeks.
I have a Waco CD-ROM with several thousand drawings, however the QCF and UBF drawings are fairly poor. My lower wing panel drawing 12301 is unreadable. Not sure if this is B wing or C. Also need the stablizer drawing 8513. Fuselage frames 11500 and 12400 are ok.
I am in initial stage of data gathering with goal to scratch build UBF. Would like to network with other builders and share info. Once I sort through drawings, I might put up drawing web site like I did for the PA-18 Super Cub, www.supercubproject.com/drawings . I like to share info and make it available for free for others to use.
This was also posted in BiplaneForum.com so feel free to comment there also:
http://www.biplaneforum.com/f42/waco...ngs-lists-5887
Reason: update
