Hey, they did put a cub on the cover of the NOTAM!
The NORDO is a lot different than it used to be. After some abuses, they made it so you have to call right before you want to use it to get the procedure.
But hey, I can't fly the FISK arrival as stated. 90 Knots is 3 knots above my gear speed. So I can either fly it at 87 with the gear down, or 90 with the gear up.
(of course I can just keep the gear up and blast in on the Warbird arrival
