Results 1 to 10 of 102
Thread: GA Turboprop
Threaded View
  1. #7
    tdm's Avatar
    Jan 2012
    Canada
    Brayton cycle turbines have very high power-to-weight ratios, but suffer from poor thermal efficiency, which is the main reason why many land-based gas turbine plants are going cogeneration or adding a rankine bottoming cycle. (There is even development on magnetohydrodynamic generator bottoming cycles.. although normally MHD is used as a top cycle, with a rankine bottom)
    學而不思則罔,思而不學則殆。
