Over twenty years ago, both my son, age 12 and I flew a Piet from Ohio to Broadhead with sleeping bags, tent, clothes and other necessities stuffed around us. I was hoping all of this stuff would cushion the impact of a crash. Thankfully, I made many good landings getting there and back.
One of my shortest biannual flight reviews was in this same Piet. As the instructor was a little bit heavy, I had to go around the trees at the end of the runway instead of going over the top as usual. He said “nice job and I have seen enough”. It was a hot day.
A good friend of mine closed off the front hole of his Corvair powered Piet. He is a big man and didn’t even want to be tempted.
Sold my Piet to a man who looked sizeable. I cautioned him about taking lessons in the Piet and to be careful of the load. So, he had his instructor check out the Piet first. Then, on the first flight with both in the aircraft, they couldn't seem to climb and crashed at the end of the runway.
So, if flown correctly, it is a great little airplane. But, weight does matter.
Matthew Long, Editor
cluttonfred.info
I don't know much about Piet's except that I think I might like to build one some day. If there are any areas where Douglas Fir is called out as an option in order to save money, use Spruce to save weight. Also if you use Stewart Systems for covering and do so lightly you can save some significant weight. I saved 10-15 lbs on my glider by removing medium weight fabric with two coats of paint and replacing it with lightweight (uncertified) fabric and a thin coat of Stewarts System. Minimal instrumentation can also save a lot over a full panel. the lightest weight engine and prop combo also is natural, although make sure that that doesn't put your empty CG too far aft. Typically the lightest weight solution won't be the cheapest but life is all about compromises.
A silly question- whats your criteria for choosing a design? might help "broaden" our suggestions
As far as the Piets are concerned , might I suggest you go to the Piet gathering in Broadhead WI- if I recall its a week or two before Oshkosh
No problem at all...
2 seats
Wood construction
Corvair compatible
Would like to be able to haul 2 adults with full fuel if possible
Should look good...nothing too...ultralightey (sorry to the UL guys out there, just not my thing)
Reasonably affordable. I like that the Piet is appx. $10k.
That's about it...the Piet hits all of them except the useful load part. I have to say I've spent some time today looking at the Fisher Celebrity and I'm intrigued. I have an email in to them to see if I could hang a Corvair off the front. I do like the bipes...
Rob
LMAO. *snort* OK Zack....I think you spend too much time around the really light end of aircraft and that's got your scale out of calibration.I doubt Bill had a full fuel tank, but the Pietenpol is definitely a heavy lifter.
Why the fixation on the Corvair engine?Corvair compatible
Love to see interest in the Pietenpol... I would agree with Zach that you visit the Pietenpol forum at http://forums.matronics.com/viewforu...05e91f66acf212
Rob, when you state "reasonably affordable" I think you are generally correct in relative terms... but unless you have a good supply of materials or are a good scrounger, I think you'd be hard pressed to build a completed airplane with engine conversion for $10k. I was hoping to complete mine for $12-$15... it looks like I'll be pressing $20k before I'm done, but I'm not upset about that at all. As my first project, there are some things that I had no idea about... plus, I was starting with an empty shop, so I've had to gather all my materials along the way. I'm not saying any of this to discourage you, and there are some things I could have done a little cheaper, but to each their own.
@Steve... Why the fixation on the Corvair? Simple... smooth running 100HP that looks and sounds great. Many say that flying behind a Corvair feels like having an electric motor out front. More? The conversion process can be accomplished by anyone. Maintenance is easy and affordable (I picked up a cylinder for $10). Lighter than an O-200 and MUCH smoother. With 1.7million manufactured, they are widely available.
Shazam! Becky Shipman's engine as completed at the recent Corvair College #22 in Georgetown, Texas.
Want to hear what one sounds like? Click this link to see John Franklin's engine run for the first time, also at Corvair College #22. http://www.10.eaachapter.org/apps/vi...air-college-22-
Cool. I've have zero experience with them one before so I figured I would ask. I don't have much use for a 100 hp engine but it's still good to know.Why the fixation on the Corvair? Simple... smooth running 100HP that looks and sounds great. Many say that flying behind a Corvair feels like having an electric motor out front. More? The conversion process can be accomplished by anyone. Maintenance is easy and affordable (I picked up a cylinder for $10). Lighter than an O-200 and MUCH smoother. With 1.7million manufactured, they are widely available.
Well, I'm not the expert on wood aircraft around here, but will throw out one name- Roger Mann. Understand all of his designs are wood.
