There you go, Zack, introducing logic into an otherwise perfectly good emotional discussion.When I want to go somewhere for fun - I fly. If I need to get there in a hurry, I drive.....
After all, rationally considered, it is a 45 minute drive to the airport, 30 minutes minimum to pull the airplane out of the hangar and preflight it (community hangar requires moving two airplanes before I get to mine). That's an hour and fifteen minutes not counting checking the wx, fueling the airplane if I hadn't done it the last time I used it, filing a flight plan if I decide to, and all the other things needed before I get into the air to travel at 85MPH indicated. Factor in a reasonable headwind and I can make much better time driving at 65MPH on an interstate.... Just saying....
