Originally Posted by
nomocom
Actually that isn't correct, unless you are simply expressing an opinion. Especially since we are on a experimental aircraft forum, how about we talk without using so many absolutes? It would be officially correct to say, "Do not use ethanol in a certified aircraft". Even then, that would be a generalization since some aircraft in Brazil are approved for ethanol and there are a few aircraft here in the US that have an STC for ethanol :-) But, in any case, +99% of the certified aircraft in the US are not.
Experimental aircraft. Do not use unless you've worked through the changes that need to be made to the aircraft. Vansairforce has some good threads on what builders have done to adapt their experimental airplanes to ethanol blends. One can read up on how ethanol and methanol is used for ADI (anti detonation injection). Reno air racers today and the powerful old radials, some of them had ADI. Also, check out the Vanguards and Greg Poe for boxer aircraft engines running just fine on ethanol. Sure, you have to make some changes, but don't we have some room for that in experimental aviation?
