Thanks for the input, guys :-)
I had originally built my plane with a handheld and external antenna. It worked fine, but I boogered up the used intercom, so decided to plunk down some change and get a brand new com radio with integral intercom. Even the stub portable antenna would prolly work fine. So I can see ,as has been pointed out, that I shouldn't worry about the radio part.
Yes, my Sonex needs to be soloed for 40 hours. I plan to have others do this for me. Even if it's ready for dual (after 40 hours), I wouldn't go up in it as a student pilot until I've gotten my hard landings and ground loops out of my system. I'm guessing 15 hours or so in a rental, then possibly the rest in the Sonex.
