Quote Originally Posted by braywood View Post
I have over 900 small 1/8" (3mm) ply gussets to cut out for ribs of my Pietenpol. One at a time is kinda slow!!
If you know of any tricks or methods you have found work well - please share!!
Thanks in advance
Mark in Northern Ireland
I've found that you simply glue a over sized piece of ply on the joint allow to harden and run a dremel tool driven laminate trimmer around all sides and get a perfect fit every time.
