Have you tried the Continental Motor tech support phone line? The TCM guys are very knowledgeable and give good advice. I went thru TCM factory training a couple years ago and was very impressed.
If you are building up a Continental A-40-2 suggest you try to upgrade it to A-40-4 standards. I also suggest you modernize it per the Continetal bulletin which I think is numbered 39-11.....I do not have it handy but I provided it to the Cub Club last year. This will improve oil pressure and to lubricate the cylinder walls. It makes a very big difference. More power and smoother running while better cooling is achieved. I seem to recall Robert W. "Mr. A-40" Thompson (now deceased) advising me in a letter that the A-40-4 was very definitely the version to have. "My" E-2 has the modernized A-40-4. It is a delightful little engine...now in a museum. I understand that one of the earlier A-40 versions apparently had a negative reputation. I am sorry that at the moment I cannot be more helpful...and I am very sorry to sound a note of caution in this matter.
I am assuming you are hoping to fly behind his engine. Many years ago when I contacted Continental they said they had no A-40 informaton on file that could help. Hopefully this has changed. EAA might have more information on file, Safety first.
Our 1932 E-2 was #26 and is our museum (Western North Carolina Air Museum)
we are keeping it as original as possible.
The Cub is in the process of a full scale recovering and restoration. You can check out the progress to date on our facebook page.
Will not be flown but we will run and taxi it around during our annual air fair.
Have checked with Continental as Kurt suggested they pointed me in the same type direction as you.
Thanks for the suggestion Cub Club is a wealth of info.
Going to try Fresno Airparts Co. to see if they might have anys of the gaskets needed.
I think that the tapes for the fabric should be "frayed".......I understand that pinking shears were not used back then. The turtle deck was bolted to the frame, but over the years mechanics welded them onto the frame as this was simpler when recovering. Mine still had the original rings and bolts to install the turtledeck to the fuselage...not exactly on the engine topic but worth noting. Original altimeter was a Zenith "Height" meter...and the compass if used would be an Aeromarine...and a Johnson airspeed mounted on a wing strut (if installed).
I was extrememly fortunate in haveing a very orginal aircraft....even the original wing struts had a very shallow minor axis...and a wide major axis...quite3 different from the J-2 struts.
You have great little project and should feel blessed.
