Hello all,
Moving my static ports from the builders location of just behind the trailing edge of the wing root, to something closer to the plans location. I'm having a problem of a bouncy altimeter and switching the altimeter out for another didn't fix the problem.
It has been suggested by someone more competent than I that we put them at STA 88 (per the plans), however, but put them down underneath the fuselage on the 45deg. section of the belly, one port each side vs. on the turtle deck area (per the plans).
The location will keep them hidden from view and be easy to install.
I'm concerned of pulses from the exhaust affecting it, any thoughts?
Piper apparently did this on the PA20/22 series with good results.
Thanks,
Russell
