Thread: What can we do?
    Jan 2024
    Sailfish Capitol of the World, Florida
    Question What can we do?
    Good morning folks,
    Please excuse my ignorance, as it is why I am here today and asking these questions...
    Wow. I really don't know much... yet
    q1) Can I fly aerobatics in an amateur built experimental?
    q1_a) ...lets say in the case of something like a Steen Skybolt with an AEIO-360 that was purchased second, perhaps even third, or fourth hand, from the builder?
    AWC:
    During a recent annual condition inspection, it was noted that there was no POH, registration, AWC, W&B, in the aircraft when it was presented for inspection. When asked about it the *new owner, presented a clear display pouch that had the registration and an AWC along with a W&B (presumably current w&b)(no POH, no AWC 'limitations')
    - Vaguely familiar with this occurrence from a previous S-LSA inspection, I ordered the package of documents from the FAA and found a 'Limitations' page.
    q2) Do all AB_ex aircraft AWC have a 'limitations' attachment? [not necessarily an aerobatic airframe, rather any AB-ex aircraft?]
    q2_a) and doesn't that attachment need to be included with the AWC, W&B, Registration, and POH in the aircraft during operation?
    q2_b) Is is it the DAR that determines if the assembly and 'build' was done to a degree of suitability for this AB-ex aircraft to be "approved" for aerobatic maneuvers?
    POH:
    As previously noted, while there was a 'checklist' in the aircraft...
    q3) what do we need to do about producing a POH or finding the missing one?
    Thank you for your anticipated replies and discussion..
    **40+ hours after my PPL checkride I was enroute and was all set up (in my mind) to over fly a traffic pattern to enter downwind under Class C airspace that I had just flown over (because I was scared to talk to ATC).... As I set it up in my head, I realized that if I overfly the pattern +500' that I'll be in the Class C airspace.
    Panic set in and I aborted my planned arrival and flew away to a nearby airport to 'ask a flight instructor'.
    I couldn't believe that I was granted the privilege of a pilots license when I knew so little.
    The CFI explained that the PPL was a license to learn.
    I still have a lot to learn and I strive to improve my understanding everyday.
    Q1: Yes, you can fly aerobatics in an Amateur-Built Experimental aircraft, presuming the aircraft's Operating Limitations don't prohibit it.
    When the FAA issues an airworthiness certificate for a homebuilt aircraft, it is always accompanied by a list of required parameters the owner must abide by. These are called the Operating Limitations. The OL for my Fly Baby states, "Except for the maneuvers described blow, this aircraft is prohibited from acrobatic flight.." It goes on to describe what acrobatic flight is (right out of the FARs) and ends with "NONE AUTHORIZED."
    Q1A: The Operating Limitations should be passed along with the other aircraft paperwork when the plane is sold. It applies to all subsequent owners. You can contact the FSDO if you want to update your OLs, but you might be opening a can of worms.
    There is no requirement for POHs for homebuilts. If it's not in the Operating Limitations, it doesn't apply. Thousands of homebuilts were built before POHs seem to become a desired item. The guiding reference for this is FAA Advisory Circular AC 20-27, "Certification and Operation of Amateur-Built Aircraft." I've got a copy at:
    http://www.wanttaja.com/avlinks/AC%2020-27.pdf
    Rules may be different for LSAs, I'm not sure.
    To skip ahead to question #3:
    Simple. Ask other owners, or just write one yourself.
    Someone in the Fly Baby community asked about a POH years ago, and I threw together a template that could be used to generate one.
    http://www.bowersflybaby.com/POH.pdf
    I've also made the Word template available....download this, and change what you need.
    http://www.bowersflybaby.com/POH.docx
    And, taking care of the last roundup:
    Q2: Yes. If you don't have it, request the records of the aircraft from the FAA. That's how I got mine...it didn't come with them.
    https://aircraft.faa.gov/e.gov/ND/
    Q2_a: Yes, it needs to be in the aircraft along with the Airworthiness, Weight and Balance, and Registration (again, no requirement for POH).
    Q2_b: Yes, the DAR is the one who decides whether aerobatics is suitable. Generally, there's a requirement for the initial flight test period to include demonstration of the maneuvers the plane will be permitted to perform.
    Quote Originally Posted by FabricGATOR View Post
    Ha! 1200 hours and 53 years after I got my Private, and after 45 years of flying from the same location, I ferried my plane to its new hangar 180 miles away. Flew around the local area for the first time, getting gloriously lost and worrying about stumbling into the Class C and Class D airspaces that I had no familiarity with.
    We're both in the same boat, Gator, regardless of how many hours/how long we've been flying. Don't feel so bad, and the best of luck! Hals und Beinbruch! (or, hopefully, not...)
    The operating limitations are considered part of the AWC and as such are required to be in the aircraft when flown.
    OLs vary according to when they were issued and the DAR who issued them. Nowadays, the DAR has less discretion and builds them from a template. The recently updated OLs for my Hatz read:
    "If aerobatic maneuvers are intended to be performed during phase II, those maneuvers must be satisfactorily accomplished and recorded in the maintenance records. Aerobatic flight testing is not complete until sufficient flight experience has been gained to establish that the aircraft is satisfactorily controllable during the aerobatic maneuver
    tested. Upon completion of flight testing, the owner/operator must make the following or similar entry in the maintenance records:
    "I certify that the following aerobatic maneuvers have been test flown, and that the aircraft is controllable throughout the maneuvers’ normal range of speeds. The flight-tested aerobatic maneuvers and speeds are _________ at _________, _________ at _________, __________ at _________, and __________ at _________." During phase II operations, aerobatic maneuvers that were not documented per this limitation may not be performed. The owner may place the aircraft back into phase I for the sole purpose of adding additional aerobatic maneuvers to the aircraft authorized maneuvers. (45)"
    If you want to put together a POH, get yourself a copy of the EAA Flight Test Manual, fly the test cards, and organize that data. You do not have to be in Phase 1 to do that.
    As for aerobatic maneuvers, if the existing Phase 1 logbook does not report any aerobatic maneuvers, you will likely have to identify nearby legal airspace (14 CFR 91.303) and talk to the FSDO so as to designate that airspace as your Phase 1 flight test area.
    "I really don't know much... yet" IF you have not had training in the proper and safe execution of the aerobatic figures that you will want to fly, please do not read a book and try it in your new-to-you aircraft. It will be wiser and safer to find a school that teaches aerobatics, even if you have to travel to do that. If you have a Skybolt, look around for instruction in a two seat Pitts. Acro can be great fun with just a little instruction but terrifying if you get into your first ever spin by yourself. Learn from a very experienced aerobatic instructor in their ship then move into your own aircraft.
