CorrosionX makes an Aviation version which is already thinned down. They also make a Heavy Duty version, which a lot of cable and satellite TV installers use on the cable connectors. I talked to a CorrosionX rep at Airventure several years ago, and he said they are all the same chemically, but the Aviation version has a thinner carrier fluid so it will creep into tight places such as lap seems, and the Heavy Duty is thicker so it will stay where it is put.
