There was never an automatic failure at <60 psi compression differential. Many mechanics would call it a failure, and often times cylinders were failing at that pressure, but not necessarily so. I have had engines that were less than 60 psi on a compression diff chk, but were still acceptable and flown for a number of hours yet before overhaul. The "master orifice" added to the gauge sets gives a comparison leakdown for large bore Continentals and was a recommendation from Continental. I never knew or cared what size the reference port was.
