Mike if I understand correctly your son will get his $5000 downpayment back from the loan company but is worried about getting the $5000 deposit back from the seller.
Was the non-refundable deposit sent with the understanding that financing was not yet in place and the deal would depend on it? If that is the case then I would echo the small claims route. If on the other hand the deposit was sent to secure the aircraft with no subjects then I would suggest he explain the situation to the seller and plead for a return of the deposit. Might get lucky.
