Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Tig Welder recommendations?
    Brrrmidji , Minne-SNOW-ta
    Something Overlooked
    Yes my TIG has Pulse , and Sequencer ... and I can use a Momentary switch instead of a foot pedal when I like.
    But the Welders don't have PRE_HEATERS
    I back up.... My Sequencer can be adjusted not only to RAMP down when you release it.
    It can also be adjusted to ramp UP for a pre-heat.
    One thing I hardly ever hear anyone talking about it pre-heat....
    I always have a quick start propane torch close by... Steel thru Aluminum...They all need it.
    Sometimes I even use it to slow the cooling. Especially on cast
    Even torch welding needs pre heat...Or you'll cold lap the metal.
    I like my water cooled TIG.... Smaller.... I even have a few "Cups" that are cut down...
    I only use a button cap on the back.... All my TIG rods are broke in half , then ground to a point.
    I have a little case with about 10 of them ready to swap out.
    Red..Old stuff , Gray and green are what I use...Steel or Aluminum.
    Quote Originally Posted by Jake Speed View Post
    A good MIG welder has advantages over the TIG.
    I would Google, the truth is out there.
    Jake Speed
    How Mig welder has more advantage over Tig.
