Results 1 to 8 of 8
Thread: Portable power pack for camping
Threaded View
    Any suggestions for a portable power supply for airplane camping?
    I've been using a Schumacher XP2260W jump starter (picture attached) for a few years. It has a lot of great features besides being able to jump start a car:
    __Two 12v cigarette lighter outlets
    __5v USB outlet
    __200w continuous/400w peak 110v inverter with two 3-prong outlets
    __LED work light
    __Air compressor for aircraft/car tire or bike tube (Schrader) with lighted pressure gauge
    __Separate low pressure air pump for inflating air mattress
    __Voltage display when DC or AC is on
    __Built-in charger with LED charging indicator (separate extension cord required)
    The things I don't like:
    __The heavy lead acid battery will need replacement soon. I'd prefer lithium to save weight. I wouldn't charge or discharge it in flight.
    __Only one USB outlet, so I plug a car triple USB adapter into one of the cigarette lighter outlets.
    __The low pressure inflator is useless because of the flimsy tube that came with it, and there's no storage compartment for that tube. So, for the air mattress, I bring a separate air pump that plugs into a 110v outlet of the jump starter.
