Fs: 2013 vans rv-12
2013 VANS RV-12: 225-TTAE, Fresh Conditional Inspection with Sale, Complete Logs, Hangared at N26 in NC. Equipped with the Upgraded VIKING Liquid Cooled, Fuel-Injected, NO TBO 110-HP Engine Which Includes:
Flywheel Replacement
ECU (Processor) Software Update
Spider Drive for Gearbox
Idle Pulley for Alternator
VIKING ENGINE INFORMATION: go to www.vikingaircraftengines.com
Sensenich Ground Adjustable Composite Prop, Dynon SkyView EFIS Featuring GPS, 2-Axis Autopilot, Transponder & Engine Monitoring. Electric Trim, 406-ELT, Intercom, Garmin SL40 Com, Wheel Pants, LED Pulse Lights, Auto Gas or 100LL, Build Manuals (Included), Excellent Paint & Interior, 1320 lbs GW, 760 lbs EW, 20 Gallons Fuel. Built by a retired United Air Lines Capt. The 2nd (current) owner is a good friend of the Builder.
REDUCED (by $6,100!) NOW $59,900 USD. Call or Text Bob Crosby at 704-905-4931 or email: bob@flyawayaircraft.com.
Thank you!
Reason: PRICE REDUCTION from $66000
