Results 1 to 8 of 8
Thread: Difference between a CCP-42 and CCP-42J?
    Nov 2016
    Hi All,
    I can't seem to find specs for CCP-42J rivets anywhere. I see that they appear shorter than standard CCP-42, so I assume their grip length is going to be less.
    When I bought a used kit, it came with a bunch of hardware. I have two bags of rivets that were labeled as CCP-42, but with one that had CCP-42J as being its actual type. Trying to make sure I use the right rivets in the correct place.
    I checked the Cherry data sheet for the CCP-42 pull rivets and did not find any letter designation for a 42J.
    The CCP-42 was a SS rivet body, a SS mandrel, a protruding head, a 4/32" dia and a 2/16" grip.
    No letter J.
    These are non-structural Cherry N rivets. Is there a difference in appearance between the two groups?
    Nov 2016
    Quote Originally Posted by Bob H View Post
    No letter J.
    Thanks Bob for taking a look. I am attaching a picture of the rivets ( the j is on the left. It's a little shorter than the standard CCP-42 rivet (0.241" vs 0.265). I also included the label.
    Thanks for any insight. The label says they are equivalent, but there is a slight difference in length as well as the head, which looks tapered away from the surface as opposed to towards.
    Those aren't Cherry Rivets... they're "Cherry Equivalent" rivets which are sold by Jet Fitting. They're of dubious origin.
    The "equivalent" term in the label makes all the difference. The 42J are not Cherry products.
    What is your end use for these?
    Nov 2016
    Thanks Bob and Ron for your response. I was going to use them where CCP-42 were called out in the plans. Given your wariness, I might not use them at all.
    In the airplane business, there are two types of structure, primary and secondary. If primary structure fails, the plane crashes (wing spar). If secondary structure fails, the plane should make it down and survive ( an aero fairing). So depending on what your application is, it may be possible to use lower quality fasteners for a low load, non-critical application, like an exhaust radiation shield, which would be inspected often. You didn't state what the application was, so to be conservative, you would choose fasteners of higher quality.
    The problem with these things is that they are of "unknown" quality, not just lower. Jet Fitting doesn't make any attestations as to what these things are other than they have a Cherry-ish part number. They won't even tell you where they came from.
