Results 1 to 10 of 83
Thread: Chrome Moly 4130 Motor Mounts - Prefab Parts?
Hybrid View
    Aaron Novak's Avatar
    Oshkosh, Wi
    I guess not since I had never heard that term before. I looked it up and I still don't know how that type of weld is accomplished. One source says "USING A STIFF. CONSTRICTED ARC" whatever that means.......
    Keyhole welding is you are using enough heat to cause the edges of the material to melt, pull back, and recombine on the back side of the weld pool. If you were to stop welding it would would like a keyhole sort of. When doing tubing work as in a cluster, the edge of the tube should pull up about 1-2x metal thickness and form a half keyhole. Otherwise think of it and simultaneously making and filling a hole, or half hole as you weld. 95% of the failed welds I cut apart look pretty, but are in fact just fillets sitting on top of the tube. Oh as a stuff constricted arc is formed by ( in the tig world ) a fairly blunt tungsten grind, high amperage and moving quickly.
    cwilliamrose's Avatar
    Nov 2013
    SW Florida
    Interesting. I use a pretty pointed grind, more like a regular sharpened pencil than a golf pencil. I don't weld fast when doing clusters for several reasons mostly having to do with having to start and stop a lot to change positions. I don't weld super fast when access is more open either. I see guys on YouTube really moving fast but that's not something I'd be successful with, even when I was younger and could see the puddle better.
    I wonder what a cluster weld would look like when you stop like the image in post 26? There's generally only one edge and with my normal fits there's little if any gap. I should play with that and see what I learn.
    Oshkosh, Wi
    Oh I know what you mean! One of the disadvantages of tig on 4130 is that every stop/start usually has some areas of the HAZ that are really hard, yet when welding a cluster man its difficult to keep moving. I know before I do something critical I will weld up a bunch of samples, section, polish and etch them to check for penetration etc. Even after all these years I still like to double check myself and improve with every project. We all have room to improve
    Hi: I am an aircraft mechanic and certified Non Destructive Testing Specialist (x-ray weld Inspector) with 40 years of experience. I don't usually comment on forums like this, unless I see a problem that is personal safety related. In the case outlined here 'welding an aircraft engine mount' - unless you are a certified AIRCRAFT welding specialist (either AWS or CWB), you should not be welding any LIFE CRITICAL components. You could be risking not only your life, but any passengers, or innocent bystanders on the ground, when you fall out of the sky. If you intend to continue with this folly, at least go out and buy the best Ballistic Recovery Parachute you can find, plus no passengers and no flying over populated areas.
    Every certified aircraft engine mount was designed by an aeronautical engineer, a welding engineer, as well as a level 3 welding inspector. Each has a specific area of expertise. It starts with the computer design and testing of the mount and they will use stress analysis to make sure there are no weak spots in their design. Then a welding jig will be designed and built by the welding engineer and level 3 weld inspector, as well as the weld procedures, which a certified aircraft welder will follow to the letter. The procedure outlines the specific filler rod, the amperage settings, the speed and angle of the welding process etc etc etc. It follows with dozens of trial and error tests to make sure the welds will hold in the most impossible situations you can imagine. All this preparation before they even begin to weld the mount.
    Welding is never as easy as it looks, especially on LIFE CRITICAL components. My recommendation - find a certified aircraft welder, who has extensive hands-on experience with this exact type of welding, as well as an approved weld procedure and welding jig. It does not matter how much it costs, if the end result is you do not kill yourself or others. OR the BRS is your last resort. I worked for two years in a helicopter search & rescue squadron - I carried more than my fair share of body bags.
    Sam Buchanan's Avatar
    KDCU
    Quote Originally Posted by nixrox View Post
    Thousands of welded experimental aircraft have been flown that were not built by certified aircraft welding specialists.......
    I consider every weld on my aircraft to be life critical.
    Sam Buchanan
    The RV Journal RV-6 build log
    Nov 2013
    SW Florida
    The homebuilding movement never would have happened (and we wouldn't be here discussing this) if the welding required a certification.
    That is the reason so many pilots have ended up dead. Murphy's Law - if it can happen it will.
    So if you are not a professional journeyman welder, EVERY weld you complete is marginal at best and blind luck if it holds.
    Transport Canada dictates what welding is acceptable for an aircraft and so far everything I have seen says NO DEFECTS ALLOWED - none, zero, zip, nada.
    If you have never taken any welding training courses, how can you guarantee that you used:
    1. A proven weld procedure, the proper amperage settings and the proper welding or filler rod, whether MIG, TIG or STICK may have been the better choice
    2. the proper metal stock that comes with the original chemical composition forms from the manufacturer
    3. maybe the composition of the filler rod and the metal required you to preheat the base material before commencing welding and post welding heat to reduce HAZ cracking.
    4. The welding you carried out might have required it to be stress relieved - which is a very long gradual heat reduction to reduce cracking
    5. the list is endless and the potential defects are limitless
    Which is why I have rejected thousands of welds and in several cases pushed welding companies into bankruptcy - because they could not weld to aircraft standards.
    So once again - if you weld any parts on an aircraft and your are not certified as an aircraft welder - PLEASE do not take any passengers on your aircraft and never fly over a populated area. PLUS always fly with one hand on the BRS.
    Have a nice day
    Oshkosh, Wi
    I appreciate your input from a safety perspective, but I do have to disagree with you on a couple points. First off on engine mount design, considering the time period most GA aircraft were designed in, I doubt most were designed by an engineer. Most were designed by the designer/fab shop and later analysis was done for TC approval, and as they are really over designed it was never an issue. Now bigger AC and Military, oh you bet they had a team designing them. A lot of what you are talking of applies to new production, and if you look back in homebuilding, the homebuilders used to seem out info from the OEMS and learn as much as they could. Now is seems there is this attitude that being a homebuilder means they can ignore history and do whatever they want and it will be fine. As for being a certified welder.....im mixed on that. The AWS criteria is really just a copy and paste from the old Military and Civilian aircraft welding tests for being and airframe mechanic, back when they taught that. That being said the certification only covers whatever process they tested in. In reality what you need is to approach this with the right attitude, test and calibrate yourself and your equipment, and make the best decisions. In general I think homebuilders should be doing more engineering themselves, more analysis and more NDT type work instead of treating what they are building as a "hot rod" with wings.
    Jul 2017
    Douglas Flat, CA
    Hi: I am an aircraft mechanic and [blah blah blah]...
    Trebuchet ride!
    Bob Kuykendall
    HP-24 kit sailplane project
    HP-24 Project Facebook Page
    http://www.hpaircraft.com/hp-24
    EAA Technical Counselor
    Oshkosh, Wi
    Quote Originally Posted by BoKu View Post
    Trebuchet ride!
