Results 1 to 10 of 37
Thread: First Time GAC Camper at Airventure - Arrival and Parking Questions
Hybrid View
    Hello All. My son and I are planning to fly in to AirVenture on Thursday afternoon (July 27th after the Thursday airshow) for several days of camping in the GAC area (leaving Sunday). Can anyone tell me how late in the afternoon the GAC area will be staffed by EAA volunteers so we can be directed to a parking/camping space. Also, does anyone have any recommendations as to what would be the best time in the afternoon to arrive over Ripon for the Fisk approach? I would like to arrive at a time when the airspace is the least crowded. Thank you.
    Shiloh, IL
    It's kind of funny that none of the information from EAA directly answers your question! If you make it in before the airport closes at 8pm, you'll be taken care of for parking and camping. Not sure there really is a less busy time. As you get to 8pm it'll get less busy, but that is because you are risking not making it in. The only real "less busy" time is the morning.
    CarlOrton's Avatar
    DFW Area
    Make sure you read the notam. Also note that the field closes to all traffic during the airshow, so if you're not on the ground before 2:30, you won't have another chance until 6-ish depending on the day's scheduled performers.
    Carl Orton
    http://mykitlog.com/corton
    Marietta, GA
    The other thing that seems to happen is that the airshow always (tm) runs long with aircraft recoveries and *special* aircraft departures, so the arrival window shrinks. And then, it shrinks more because they seem to prioritize departures over arrivals in the evening...
    Jeff Point's Avatar
    Milwaukee
    They do this on purpose and out of necessity. Every day there are a pile of airplanes waiting to leave as soon as the airport opens after the airshow, and we need to flush them all out before we start taking arrivals or it would be mass chaos. Besides, we need to make room for the new arrivals. So this might be inconvenient to arrivals but in the larger picture it makes a lot of sense.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    Yeah, you want to let the departures out. It generally takes about 30 mintues from the time the airport is turned back over for operations after the airshow. 6:30 is the planned time but it all depends on how the airshow goes. We have to wait for the airshow people to turn it back to the FAA and then the FAA tells us (through a chain of command) that we can allow engine starts on the ground. It would be gridlock to allow arrivals at that time. There's plenty of time to get the planes on the ground before the airport closes at 8PM. If they let you land here will be someone to park you. You won't be able to register until the next morning if you get there late (the registration booth closes up earlier) but that is of little consequence.
    Oshkosh, WI
    Note that per NOTAM page 1, the Monday to Friday airshows are scheduled to end at 6:30 PM and "arrivals at Wittman Regional Airport are normally resumed 30 minutes after each afternoon airshow." That makes the expected time window for post-airshow aircraft arrivals 7:00 to 8:00 PM.
