The nice thing about the antenna I posted, it covers all area's without a dead spot above or bellow the airplane. You do need a wooden framed airplane to use this style of antenna.
I should have mentioned that the L2, L3, and L4 all have steel tube fuselages covered with fabric.
On my Kolb I mounted the handheld's original rubber duck antenna on the bottom of the fuselage with an extension cable. My Fisher came with a wire antenna like this one mounted on top of the upper wing center section. Both worked just fine.
On my L-3C, I installed an aluminum ground plain plate on the top of the fuselage just aft of the observation window. The plate was installed under the fabric using rubber lined Adel clamps. The larger the plate, the better. A bonding wire was connected from the plate to a fuselage tube by drilling a hole in the tube for a #4 screw and a crimp type wire ring terminal. My L-3 was equipped with wind driven generator and a motorcycle battery to power the radio.
