Page 10 of 10 FirstFirst ... 8910
Results 91 to 99 of 99
Thread: Installation FAQs
  1. #91
    I think I mentioned this before - perhaps in another topic.
    Unless I'm mistaken, the SW Student edition lags behind the commercial edition. A bit like buying bread - If you want today's bread, come tomorrow.
    So use your serial number to install SW 2020 (instead of 2021).
    Let us know how it goes.
    Hello and thanks for the info. I am fine with SW 2020. It took a second to realize I needed to go back to https://www.solidworks.com/sw/education/SDL_form.html to be able to select the 2020 option. Thanks for your help!
  2. #92
    How long does it typically take for the EAA serial number? I submitted my request via the EAA website a couple of days ago and have not gotten anything. I checked my spam folder.
    Oddly, the page says "Please fill out the form to access 3DEXPERIENCE SOLIDWORKS for Makers at a 50% discount".
  3. #93
    Israel
    Unfortunately I'm not the guy to speak to about this and I don't know who is
  4. #94
    So I have had it installed for a year and a half now but for some reason when I try I get a System Error "The code execution cannot proceed because VCRUNTIME140_1.dll was not found. I've attempted to modify and install the files I was missing but I keep getting that error. I then tried repair and I get "Internal Error: The Windows Installer for this product component did not run as exprected: INSTALL." It then tells me to contact technical support but I don't think we get tech support on the edu sooooo I'm kinda stuck here hoping someone has a clue. My version is good until Dec of this year.
    Figured it out. Was a driver error. Updated latest windows and Nividia Driver. Dang Quadros are finicky.
  5. #95
    I have not been able to find a link and instructions to download Solidworks. I sent an email to contact EAA and received this information: CSE: 4SX3J2, TKT: ocfRa0 and this link: http://www.eaa.org/solidworks which does not have links or instructions. SOLIDWORKS Info 2019.pdf I'm not sure how to proceed.
    John
  6. #96
    EAA Staff David Leiting's Avatar
    Feb 2017
    Quote Originally Posted by Pattern64 View Post
    John
    Hi John,
    The new access instructions for SOLIDWORKS can be found here - https://www.eaa.org/eaa/eaa-membersh...-software-form
    Once you fill out the form, you will be able to download a PDF with the instructions.
    I hope this helps.
    Thanks!
    David
  7. #97
    The hyperlinks in the pdf did not work for me. (There were no links)
  8. #98
    Feb 2024
    does anyone have the download instructions for SW.
    I purchased the license a month or so ago and deleted the email.
    I want to load it on a laptop I just purchased.
    Emails I have sent to Cory seem to to keep getting kicked back
    Adam Rigden
    EAA 1051976
  9. #99
    Eric Page's Avatar
    Toledo, WA
    You might have better luck sending a Private Message to David Leiting (see post #96, above, and click on his name). If that doesn't work, you might try calling the phone number that Cory listed in post #47, on page 2 of this thread; perhaps it will still ring in the correct EAA office.
    I could be wrong, but I don't believe Cory is with EAA any longer. I have a vague memory of receiving an email or PM from him more than a year ago in which he told me that he was no longer an employee.
    Eric Page
    Map of Landings
