ABSOLUTELY!
I could argue to have and abort point on every takeoff. Whatever you call it and define it, it should be a point at which you should continue or go. Of course, if it's a single engine that point may be long after takeoff.
One should also have "checks" during the takeoff roll.... engine parameters, acceleration, speed check, etc., and at any point if those are not up to normal, an abort should be executed. And, if it's a short field, there should be a point on the runway where you assure that you have the performance to continue. I could argue to have 80% of the speed at the halfway point.
