Just in case, I will inform you about the available propellers.
for today I have in stock:
1) 2-blade propeller with a diameter of 2000 mm (78.7"), saber-shaped, hub 101.6 mm - for the pulling motor Rotax-912-914,
2) 2-bladed propeller of left rotation with a diameter of 1750 mm (68.9 inches), straight blades, hub 75 mm - for the pulling motor rotax-582/3-3.47,
3) 3-bladed 1750 mm (68.9"), pulling, right, with a hub 75 mm, shortened saber - is no longer available,
4) 3-bladed pushing left propeller 1750 mm (68.9"), truncated saber - already gone,
5) Wooden left rotation propeller with a diameter of 1400 mm (55.1 inches) for Sauer S2100,
6) a 72*44 wooden right-hand propeller for a 115-horsepower Continental.
7) 3-blade propeller for an engine with a capacity of up to 150 hp, saber-shaped blades of right rotation, pulling, there are traces of installation on the hub
8) right-hand drive propeller for R-912-100 with a diameter of 1805 mm, truncated saber
