Originally Posted by
BrianPlas
Dave, this may get a bit complicated and long but I will do my best to answer your question.......let's say your one your way up to OSH, when you contact the first controller, request (FF) flight following "with handoffs" to OSK and the controller will put you in the system and you normally won't be dropped and then have to start over with the next controller, buuuttt You want to traverse Chicago "B" airspace and Chicago doesn't like to deal with VFR traffic because they are so busy with BIG paying traffic. Remember the FARS say "work load permitting". Now that's not to say they won't but don't be surprised if they don't give you FF. The east sides freq. is 124.35. If you will be flying through multiple airspaces, ask "with handoffs" and you will find it makes you flying more enjoyable and safe. I hope this helps you. Brian
