Thread: LSA Champ on FLoats
    LSA Champ on FLoats
    7AC-Conv Champ with an O-235C2C engine. Engine time is under 700 hrs. TTSNEW, 400SOH. This is a 2400 hr. engine. Annual is due and will be completed as soon as my mechanic can get to it.
    Aircraft totally refurbished mid-90's. This plane is modified with 13 gallon wing tanks for a total fuel capacity of 39 gallons, droop tips, VG's, fish pole tube, Whelen stobes, full plexiglass seaplane door and side opening rear window same size as in the Citabrias.
    Metal prop and has wheel gear and currently on PK 1500 floats. Has starter and battery but no charging system so there is no requirement for a transponder. Plane is located in north central MN. $43,000 or reasonable offer.
    im_planecrazy at hotmail dot com
