As others have stated, best to start with zoning and state transportation law. Here in Arizona, our Department of Transportation regulates aviation, but only within 70 NM of what they deems a congested metro. I live well outside of this boundary, so they have no objection or authority on my strip. Navajo county requires a Special Issue Use Permit, which goes through two public hearings and an environmental impact survey (water drainage). The feds require a 7480-1 submitted too assure your strip will not adversely effect air safety. A few states have aviation departments which can guide you through all the processes, permits, and waivers you may need in your location......which may save you money and spinning your wheels, sometimes the process is easier if you take the steps in a specific order and someone who is in authority and familiar with the process can be very helpful. Good Luck.
Best Regards.......George
