Originally Posted by
vaflier
I would inspect all the vacuum hoses , you may have a broken hose or one may have come loose. If that shows no problems I would remove and plug the hose from the engine driven vacuum pump and then try the backup system. If still no vacuum reinstall hose to the engine driven pump and block the line from the backup unit and try again. If all is ok then you have a failed pump that is allowing air to flow back through it. Good luck.
