Thread: Radio system and wooden airplanes....
    I have done a lot of reading on everything needed to do a proper installation of a radio system in a wooden airplane. They offer all sorts of different equipment to hook up a handheld. I believe most of us in these little airplanes use handhelds.
    When running or flying a ultralight with a two stroke I never had a problem. Now that I have gone to a wooden airframe with a 4 stroke engine that has a mag I can not even use my radio for feedback or something. I can hear just fine but as soon as I push the button to talk it makes all sorts of noise.
    I mounted my antenna all the way back by the tail feathers, on a piece of metal that covers the joint between the horizontal and vertical fin.
    What do I need to do to make this work, and when they say shield your ignition wires just how do you go about doing this? Does the P-lead from the mag need to be shielded?
    I did own one other wooden plane but it was a two stroke and that handheld worked great. I could talk to people 30 miles away. I was using what looked to be an antenna made to mounted on a car. No ground plane, I mounted this antenna to a piece of plex-a-glass that was a small window in the top of this Bushstyle airplane. If interested here is a video of this plane. If you look you wil see the antenna mounted on the top. That is a cover for a recovery chute to deploy out of. No chute so I mounted my antenna to it and screwed it shut so it would never open.
    http://www.youtube.com/watch?v=ZBGro7gJfy8
    The system I use today is that same system, I left the antenna on that bird when I sold it but the radio and PTT button and helmet are now in the plane I fly today, and it works like crap and use to work so good.
    H.A.S.
    Is your current airplane uses the same sort of antenna as the one in the video, that I see mounted above the cabin, it won't work without a larger metal ground plane. You would be best served by using one of the dipole antennas like the Bob Archer or Advanced Aircraft Electronics ones. If the article here -> http://www.aeroelectric.com/articles...r_Aircraft.pdf has not been on your reading list, it may offer the solution to your problem.
    Wes the system in the plane you see had no ground plane and that radio worked great in that airplane. I could hear people from 30 miles away and I had no problem talking to anyone. I talked with one friend in his 172 and he was 15 miles out. He said I was loud and clear.
    I wish I would have kept that antenna. I kept everything but the antenna. I am the one who installed that system. When I purchased that plane it had no radio. Same style plane made of wood the only difference is one had a two stroke and one has a 4 stroke and that antenna.
    Does the noise occur when you transmit with the engine off?
    You know Ron I have never tried this. I will try this and get back with you. My plane is in the shop for condition inspection and some upgrades but I believe I can do this with her in the metal hangar, but then again maybe not but I will try.
    Thanks for this advice, no idea why I did not think of this.
