I have an easier solution since I fly a Weight Shift Control Trike. I have one camera mounted slightly above and behind my head on the mast and one mounted near the right wing tip on a washout strut. With it, I record all flights and analyze all landings. It has greatly helped my landings. Examples below. Unfortunately, engine noise makes the forward movies waverer. I'm moving the camera to the front strut to get it further from the engine to see if that helps.
Try to get a wing tip mount for the most useful information on your landings.
http://www.youtube.com/watch?v=2mTh6VEDeZ4
http://www.youtube.com/wesfelty#p/a/u/2/130-umnmEuc
