Results 1 to 8 of 8
Thread: new aircraft tie down in town
    turbo's Avatar
    just received my http://www.stormforcetiedowns.com/ from my trip to osh and other points west. this is lookn like a great solution to the tie down issue. will give a report when i ground it and give it a good pull with the auto. thanks to tom for doing some research on a well needed tool.
    Ed DArcy 'Turbo'
    R-44 N7511G 1,300 hrs / RV-6 N26ED 4,700 hrs / helicycle 100 hrs
    Stuart, FL Hartford,Ct Virgin Gorda, BVI
    Eric Page's Avatar
    Toledo, WA
    Did you watch the promo video they were showing at their booth? It showed a vehicle pull test that held for an impressive period, but ultimately destroyed the product.
    Eric Page
    Map of Landings
    Why do you think that destroying in lieu of releasing isn't a bad thing. Actually, I have some rather bent claws that held in 70 knot winds in Wyoming as well.
    It still looks rather heavy despite the claims. A friend had a real neat set of tiedowns that were essentially a carbon fiber hockey puck and carbon fiber anchor nails. Came from Australia but the company seems not to exist any more.
    NE USA
    I picked up a set back @ OSH in 2009. They have performed very well as far as I am concerned.... and the price is right where it was in '09. Imagine.
    Eric Page's Avatar
    Toledo, WA
    Why do you think that destroying in lieu of releasing isn't a bad thing?
    I don't. The OP said he would "give a report when I ground it and give it a good pull with the auto." My point was that this test would likely destroy his shiny new anchors.
    Eric Page
    Map of Landings
    Christopher Ingram's Avatar
    Feb 2012
    Glendive, MT
    Those look really quite simple compared to the usual "screw in dog leash" type, I think i might make me a set. 2"x2"x1/4" angle iron, some 5/16" U-bolts and some large nails.
    Thanks
    Yeah, that's what I thought Chris. While the claw has some cast pieces, this one looks like something I could make in my garage. I suspect they're banking on the "Yeah you could make this, but will you?" strategy.
    Feb 2012
    Glendive, MT
    I think even using some aluminum angle would work just fine and wouldn't weigh much. it would only take about a half an hour to make these.
    Still a great idea for a simple yet very effective tie down. I give them a thumbs up for the simplistic ingenuity!
