Wes, wing-wagging into the box is a dutch roll no? ...even if you only go to 45 degrees and not knife edge. Do this coordinated with the ball in the center and you will be off heading going into figure one, meaning the nose is going off heading (not on point during the process). This one requires opposite rudder to keep the nose on point, which makes the maneuver very uncoordinated.
