Wonder what he's planning on doing - ? I think it's also got a lot to do with $$ you have to spend - if you have the body - and aspirations to do aerobatics - start with a decatholon or CAB - etc... and move into other types - if you are able to progress. I have an RV4 - it's fun - I plan on competing in primary and hopefully sportsman this fall in rocky mountain house - I've registered. Definetly without a inverted fuel and oil it's a huge issue - I have to be quite carefull not to do damage to my motor and or stall the motor - takes more work to make the figures look nice and keep the engine happy at the same time. I would not really consider even with a full inverted system going beyond the sportsman with my plane. I would love to have a edge 360 - or extra 200 - or 260 etc... and prehaps that will be my next type of plane. I like those harmon rockets and F1 rockets as well but they are built for doing one thing really well that is going fast. faster you go - makes doing acro harder - as it exerts way more presure on the control surfaces etc... and can pull more G's too. Most aerobatic planes are highly manuverable - and very predicatable - stall spin characteristics etc... fast of course but usually for climb more than top speeds. 3000 feet per min - climb rates - etc... 200mph top speeds are prefectly adequate. Start going 250mph - and try staying in a box. So again I say it simply depends on what you want for yourself - and the coin you have to spend. If you want to do competition aerobatics - stick with planes designed for that purpose - if you want a sport plane that can do some aerobatics - then the RV series or HR's are fine for that - but are limited in what they can do re: aerobatics. I'm already hoping that a win fall - comes my way so I can up grade - and hopefully do some dual down in WA state to learn some intermediate aerobatic manuvers.
I did have a look at those F1 kits - compared to say doing a HR 2 - it's more pricy - but I think they are very well designed and built - the QB kits from Team Rocket I believe they are called if they are still in business - are amazing and well worth the coin - since much of the "hard" work has been done for you. wings are mostly completed - fuse mostly completed - etc... still meets the 51% rule though. To build a HR 2 - you get a RV4 kit from Vans - minus some parts and the HR kit from John Harmon - and get ready for about 2years min - of work. 1800 hours anyways. The F1 can be done in about 800 I believe they say. Not sure of the cost difference. I know they have 2 types of wings now - one is the laminar flow - the other is the sport wing - similar to the HR 2 - wing - design - better for acro then the other wing - I believe. there are lots for sale though here and there - and that's a good way to go too - if you can afford that - as you can be up flying quickly that way.
Also recommend - tranisition training - I did 5 hours with Mike Seager in Veronia OR - it was a blast - he's aweseome and very reasonable too. I would not of flown my RV4 without that training. Dido with a HR 2 or other. And consider yourself lucky as there are a lot of places where you can train to do aerobatics - we don't have that luxery here unfortunatly. Best of luck. Let us know what you decide - HR - or RV etc... or other. there are some great deals on some acro machines these days too - Giles - etc... check barnstormers or trade a plane etc... and or any of the local chapters.
