Originally Posted by
Eric Page
As a pilot who flies a TCAS II equipped aircraft for a living, and having seen how valuable it can be first hand, this intrigues me quite a bit. I really like the display of relative speed so you can see your rate of overtake. Having that alone could prevent a good number of go-arounds.
After reading (only) Appendix B of AC90-114B and watching your video, I have a few questions:
1. The AC makes it clear that using CAVS isn't permissible just because you have a CDTI (or a portable facsimile of one) on board. It requires that you apply to the FAA and receive authorization. Appendix B talks about submitting your application to your principal inspector (an FAA person who oversees air operator certificate holders). It sounds like it's intended as a traffic-expediting tool for commercial aircraft other than Part 121 airlines. Is there any guidance available for private GA aircraft to take advantage of this under Part 91 (other than Subpart K)?
Maybe I should have made more clear that the TrafficAssist product is NOT intended for PART 119—"CERTIFICATION: AIR CARRIERS AND COMMERCIAL OPERATORS". It's mainly for FAR Part 91. General Aviation.
2. The AC requires a TSO-C195b approved ABS-B In system. To the best of my knowledge, no portable device (i.e. neither the DIY Stratux nor any Android phone or tablet) is TSO'ed. How are you using those items to implement CAVS?
Again for general aviation one can use portable devices. There are plenty of them beeing used in the General aviation realm
3. The AC also states that your application must include airplane flight manual compliance documentation, operations manual and checklist revisions including system description and both normal and non-normal procedures, maintenance guidance, revised minimum equipment list, and training programs for pilots and mechanics. How do GA operators get around this snowstorm of paperwork?
