Thread: G3X Touch Indicated Airspeed Anomaly
    I started going over my downloaded data from my G3X Touch for another issue and noted something strange that I hadn't seen while in the plane. When the plane was not moving (and the wind was calm) the data showed an IAS of between 17 and 18 mph. I wondered if this was related to propwash but when I go to the beginning of the data (when rpm was 0) it showed the same thing. In addition, the IAS does not increase from about 17-18 until the groundspeed comes up (even at increased rpm) which suggests that it is not propwash. I was curious so went back over several other flights and they all show the same thing. I don't geneerally pay attention to IAS while on the ground so I don't know if this is what is displayed on the PFD as well but I would have to assume so. Any thoughts?
    sonex293's Avatar
    Cary, NC
    We had the same issue with our G3x Touch. Ended up being a faulty GSU25 air data unit. Garmin replaced it and it’s been fine since.
    Sent from my iPhone using Tapatalk
    I’ve run into some odd IAS readings on my G3X Touch too, especially when I wasn’t moving. It could be that the pitot tube is still catching a little airflow even when you’re on the ground, which messes with the readings. I’d definitely suggest checking the calibration because I’ve had success fixing similar issues that way. Also, I found it helpful to check out forums or talk to other pilots; sometimes it’s a common quirk with the system, and it’s nice to see how others have dealt with it.
